Re: [Nagios-devel] nagios startup script patch
This is a multipart message in MIME format.
------=_NextPart_000_0045_01CBDD82.EAF47F50
Content-Type: text/plain;
charset="iso-8859-1"
Yes, I'm aware of that, thanks.
As I said, patch is minimalistic, it does not implement anything, it =
just
intends to optimize the startup script...
Actually, the reason I looked at the startup script was to see how this
faststartup was handled at the init level... and it is not.
Also, I'm not interested in objects cache : when I usually reload config =
(I
am/was avoiding restarts), it's because the config changed...
So, what this patch does is actually take advantage of the building
optimizations, and avoid the useless duplication of checks.
If you look at the current init script, a restart *really* checks twice =
the
configuration using "nagios -v", and it furthermore doesn't de-activate
circular path checks when starting nagios. This is 3 tests for circular
dependencies. And 2 for a simple server start using the init script.
Since circular path checks are what seem to take most of the startup =
time, I
thought it might be good to take advantage of this built-in =
optimizations at
startup... ?
Regards
> -----Message d'origine-----
> De=A0: Jochen Bern [mailto:[email protected]]
> Envoy=E9=A0: lundi 7 mars 2011 17:54
> =C0=A0: Nagios Developers List
> Cc=A0: SCHAER Frederic
> Objet=A0: Re: [Nagios-devel] nagios startup script patch
>=20
> On 03/07/2011 05:29 PM, SCHAER Frederic wrote:
> > Attached is a patch that intends to remove duplicate configuration
checks
> > when (re)starting nagios.
> > Especially, this divides by three nagios restart time for large
> > configurations since the restart sequence is no more "verify - stop =
verify
> > - start + nagios paths check", but only "verify - stop - start =
without
> > checking paths" .
> > Without patch, and because of circular dependencies checks, my =
nagios is
> > taking 15 minutes to restart
>=20
> Are you aware that there *already is* a mechanism to restrict config
> checking to a single "noninterrupting" check run?
>=20
> http://nagios.sourceforge.net/docs/3_0/faststartup.html
>=20
> Kind regards,
> J. Bern
> Jochen Bern, Systemingenieur --- LINworks GmbH
> Postfach 100121, 64201 Darmstadt | Robert-Koch-Str. 9, 64331 =
Weiterstadt
> PGP (1024D/4096g) FP =3D D18B 41B1 16C0 11BA 7F8C DCF7 E1D5 FAF4 444E
> 1C27
> Tel. +49 6151 9067-231, Zentr. -0, Fax -299 - Amtsg. Darmstadt HRB =
85202
> Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver =
Michel
Content-Type: application/pkcs7-signature;
name="smime.p7s"
filename="smime.p7s"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...[email truncated]...
