Hello all,
i'm after long googling around, it seems to me there no options to remote monitoring a LSI Megaraid controller installed on Windows server (w2003 or w2008).
I've setup NCSclient++ with success but didn't found neither the correct component to install server-side, nor the right plugin to use in nagios-side.
Many thanks for any light on this
Emilio
LSI megaraid monitoring
tonyyarusso
Re: LSI megaraid monitoring
Hmm, there are a few relevant plugins on the Exchange, two of which are for Windows. I can't tell if any of them are in complete and working order, but they may at least give you a starting point if you can program in VisualBasic.
