Re: [Nagios-devel] Nagios 1.2 fast IO-patch
--=-TNF3SomPfpO5N5rFowPN
Content-Type: text/plain; charset=iso-8859-1
It would be better to use mmap instead of
read the entire file ?=20
if 20 users do that at the same time
with a big log file, it could be nasty... one of my nagios server
have only 32Mb of ram...
Bye
On Mon, 2004-03-22 at 17:07, Andreas Ericsson wrote:
> Hi all.
>=20
> I wrote this patch the other day when I was juggling with automating=20
> reports (avail.cgi), and I noticed that parsing the files alone took 8=20
> seconds, even though it was less than 3MB of data.
> The solution was to rewrite the read_line() function in cgiutils.c to=20
> utilize larger read()-buffers and thus allow for IO bursting.
> With this patch applied execution time went down to 0.7 seconds.
>=20
> It also solves the problem with not-newline-terminated rows not being=20
> read in the configuration files (discussed earlier).
>=20
> The only drawback is that it will take forever to parse files that are=20
> larger than you have physical RAM available (the kernel will utilize th=
e=20
> swap-space), and will fail completely (pretending the file is empty) if=
=20
> the file is larger than the physical AND virtual RAM combined. However,=
=20
> considering that it already takes forever even with relatively small=20
> files, this shouldn't be a problem.
>=20
> This patch is also available for 2.0a1, but I haven't had time to test=20
> it to any extent with that release.
>=20
> Tested on Openwall GNU/*/Linux, kernel 2.4.24-ow1 running on;
> a) Celeron 2.0Ghz with 256MB RAM and a single 40GB IDE-disk.
> b) Pentium 4 HT 2.8Ghz with 512MB RAM and dual 120GB IDE-disks with=20
> software RAID-mirroring.
> c) Dell Inspiron PIII 866Mhz with 256MB RAM and a single 20GB IDE-disk.
>=20
> Cheers,
> Sourcerer / Andreas Ericsson
> =20
--=20
Eric BOLLENGIER, Administrateur Syst=E8me - Poste 1325
SIGMA Informatique http://www.sigma.fr
3 rue Newton, BP 4127, 44241 La Chapelle sur Erdre Cedex
tel : 02.40.37.14.00
Content-Type: text/html; charset=utf-8
Bye
Hi all.
larger than you have physical RAM available (the kernel will utilize the
Cheers,
<TABLE CELLSPACING="0" C
...[email truncated]...
