[Nagios-devel] nrpe, arguments and security
The nrpe SECURITY file, the dont_blame_nrpe parameter, the log messages
etc gives a clear message: enabling command arguments is extremely
dangerous. It doesn't say *why* this is dangerous, though.
nrpe tries to filter out "nasty" meta characters, but it doesn't do this
good enough. Several characters, such as # and ; are missing from the
NASTY_METACHARS definition. This is a security hole. Assume a nrpe.cfg
with:
dont_blame_nrpe=1
command[echo]=echo $ARG1$
In this case, arbitrary commands can be run, by running:
check_nrpe -H targethost -c echo -a 'foo; myevilcommand'
or
myevilcommand'
In short: I'm not happy with the current implementation. It should be
possible to provide a *safe* way of passing arguments to plugins. The
attached patch limits the arguments to [A-Za-z0-9 ]. Can anyone find a
security problem with an implementation like this?
(The main problem with the current implementation is that nrpe executes
programs through the popen() library call. It has been known for a long
time that this call is pretty unsafe. In this case, however, it's a bit
hard to get rid of it: We would have to split the string in nrpe.cfg into
an argument list. Limiting the allowed chacters is much simpler, and has
an additional advantage: The executed command/plugin may eventually pass
on it's arguments to a shell.)
I've looked at nrpe_nt as well. Since it does not execute the command
through a shell, it should be much safer. Limiting the arguments to
[A-Za-z0-9 ] is probably a good idea anyway.
Comments?
Index: nrpe.c
RCS file: /cvsroot/nagios/nrpe/src/nrpe.c,v
retrieving revision 1.35
diff -u -r1.35 nrpe.c
--- nrpe.c 20 May 2004 22:41:02 -0000 1.35
+++ nrpe.c 30 Nov 2004 14:41:56 -0000
@@ -34,7 +34,7 @@
#define DEFAULT_COMMAND_TIMEOUT 60 /* default timeout for execution of plugins */
#define MAXFD 64
-#define NASTY_METACHARS "|`&>buffer)==TRUE){
- syslog(LOG_ERR,"Error: Request contained illegal metachars!");
+ if(contains_illegal_chars(pkt->buffer)==TRUE){
+ syslog(LOG_ERR,"Error: Request contained illegal chars!");
return ERROR;
@@ -1409,14 +1409,14 @@
-/* tests whether a buffer contains illegal metachars */
-int contains_nasty_metachars(char *str){
+/* tests whether a buffer contains illegal chars */
+int contains_illegal_chars(char *str){
int result;
if(str==NULL)
return FALSE;
- result=strcspn(str,NASTY_METACHARS);
+ result=strspn(str,ALLOWED_ARGUMENT_CHARS);
if(result!=strlen(str))
return TRUE;
Peter Åstrand Chief Developer
Cendio www.thinlinc.com
Teknikringen 3 www.cendio.se
583 30 Linköping Phone: +46-13-21 46 00
