Ben Clewett wrote:
> Dear group,
> I have a problem parsing the Nagios performance data and wonder if any
> member can suggest a solution. These have the default file names
> 'serviceperf.log' and 'hostperf.log'.
> I wish to parse and delete these every minute. But I cannot delete them
> as Nagios holds the file open. Stopping and starting Nagios every
> minute is not really an option.
You can empty it without deleting it.
simply 'echo -n > hostperf.log ; echo -n > serviceperf.log'.
The files will be truncated, but still have identical filehandles and
directory links, so nagios won't be disturbed.
This can, however, create a race condition (i think last in wins), so
you might lose information if you do it this way, but it's the best I
can think of without having a daemon hook the writes.
> Really I want to pass a command to Nagios to request the deletion of
> these files. However, if there is a delay between Nagios getting the
> command, and Nagios deleting the files, information will be lost.
> Because my program is sitting waiting for the deletion without parsing.
> Ideally, I would want Nagios to write to a tmp file, then on getting a
> command, close the file, move it to the true file, and open up a new tmp
> file for it's self. Or get Nagios to continuously close the file after
> every write, making it delete-safe. But this might effect performance??
This would require severe diskthrashing, which is less than optimal.
> If any member has any ideas, I would be extremely interested.
> Kind regards, Ben.
> This SF.Net email is sponsored by: SourceForge.net Broadband
> Sign-up now for SourceForge Broadband and get the fastest
> 6.0/768 connection for only $19.95/mo for the first 3 months!
> http://ads.osdn.com/?ad_id=2562&alloc_id=6184&op=click
> Nagios-devel mailing list
> [email protected]
Sourcerer / Andreas Ericsson
OP5 AB
+46 (0)733 709032
[email protected]
