On 24 Feb 2006 at 16:25, Ton Voon wrote:
> Hi!
> Ethan, will you consider this patch for Nagios.
> Premise is that we'd like to be able to define a view on a subset of
> services using the contact definitions, but this contact will have no
> permission to run commands. This could be done through Apache
> configuration, but is best done in Nagios.
> So the implementation is to have a new option for contacts:
> issue_commands. The default is to allow, for backwards compatibility,
> but if you specify 0, then you will get the standard error page re:
> authorisation.
> The patch is here: http://www.altinity.org/
> Ton
Sounds good. I'll apply this to the 3.x development code. FYI, I
changed the variable from issue_commands to can_submit_commands.
Ethan Galstad,
Nagios Developer
Email: [email protected]
