Hash: SHA1
On 22/12/07 05:30 AM, Wolfgang Barth wrote:
> Hi,
> I'm using mod_auth_kerb (Apache2) for authentication. My contact names
> are like [email protected] (username@REALM).
> Nagios shows correctly the full username@REALM in all cgis with one
> exception: in cmd.cgi the field "Author" is filled with
> barthw@ELI
In our systems we used the attached patch (written by me some time ago)
to remove domain part and make the username lowercase (Windows AD
doesn't care about the case while the cgi do, so this avoid us problems).
The patch is against mod_auth_kerb-5.3 but since it's pretty simple it
might as well apply fine on future versions.
> but should be [email protected]. It is not a real problem,
> because the field is only a comment, but it should be mentioned there.
> BTW, single sign on works perfectly for me
We have some problems with that and never took time to investigate. What
version of the various software did you use? Any particular document you
followed? You're authenticating against a Windows Server 2003 based AD?
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHbaJQ6dZ+Kt5BchYRAnH0AKCUja2t5VlNvjoTImH+M4Yp9i5mOACfadFO
myFf1U7t+n7WNOGM8lTOBhs=
=J0j4
-----END PGP SIGNATURE-----
