Re: [Nagios-devel] PATCH: /cgi/cmd.c -> string_to_time()
Michal Zimen wrote:
> Hi
> If user submits time with bad format (e.g. Re-schedule the next check
> for this host) there is no checking function for that.
> Even in this case the input string is evaluated as "OK".
> I've attached little fix for $SUBJECT.
> kind regards,
> Mizu
Thanks for the patch Mizu! This has been applied to the 2.x and HEAD
(3.0) CVS branches.
Ethan Galstad,
Nagios Developer
Email: [email protected]
