Re: [Nagios-devel] [PATCH] Show the .cvsignore files some love
Ethan Galstad wrote:
>>> My apologies. It seems as though using geany for external
>>> mail editor wasn't such a stellar idea. Ugh
>>> [ a lot of malformed patch junk ]
>> Was the attached git-patch usable, or do you want me to re-send?
> It didn't apply cleanly, so I just made the changes manually. Not sure
> if the git format was throwing things off or what...
Hmm. It works here, with patch -p1 < file (patch --version 2.5.4). What
version of patch are you using?
git-apply works without a git repo otherwise. If you add --verbose to
it the output is fairly similar to that of patch. Use --whitespace=strip
to get rid of trailing spaces in patches.
OP5 AB www.op5.se
