[Nagios-devel] base/utils.c improvements...
Near line 2740 is the place where an error message is printed if
fcntl(lockfile,...) fails.
The code there is a bit lame.
Please consider changing the code from:
if(fcntl(lockfile,F_SETLK,&lock)<0){
snprintf(temp_buffer,sizeof(temp_buffer)-1,"Lockfile '%s' is
held by PID %d. Bailing out...",lock_file,(int)pid);
write_to_logs_and_console(temp_buffer,NSLOG_RUNTIME_ERROR,TRUE);
cleanup();
exit(ERROR);
to:
if ((errno == EACCESS) || (errno == EAGAIN))
'%s' is held by PID %d. Bailing out...",lock_file,(int)lock.l_pid);
else
snprintf(temp_buffer,sizeof(temp_buffer)-1,"Cannot lock Lockfile '%s'; %s. Bailing out...",lock_file,strerror(errno));
cleanup();
exit(ERROR);
Note the change from pid to lock.l_pid for the "existing" error message.
H
