Re: [Nagios-devel] trying to find problem in cgi/status.c
On Fri, 2005-04-03 at 18:17 +1100, John Warburton wrote:
> OK
> Since no-one has responded (does anyone else live here?), I will report
> back as to what I had found...
> One of our other admins set up a host definition without a
> check_command. This is fine, as the documentation says "If you leave
> this argument blank, the host will not be checked - Nagios will always
> assume the host is up." (see
> http://nagios.sourceforge.net/docs/2_0/ ... .html#host)
> Unfortunately, the code, when displaying host specific stuff (eg the
> "Host Detail" button, or 2-D status map), will assume that there is a
> value in the data structure for "plugin_output".
> This explains my seg fault.
I don't quite understand, you had a check_command defined but it was
blank?
I tried this but it throws an error for me when I verify the
configuration.
As for actually having an undefined check_command in a host definition,
I use a few of these in 2.0 and they work as expected. They simply list
(null) for output in the cgis.
- Matt
