Thanks for the input Ethan. I've made progress but I'm still not seeing
status.dat created. See inline comments --
> -----Original Message-----
> From: Ethan Galstad [mailto:[email protected]]
> Sent: Tuesday, December 02, 2003 9:10 PM
> To: [email protected]
> Subject: Re: [Nagios-devel] status.dat not created
>=20
> The status file is only created/updated:
>=20
> 1. At regular intervals when aggregated updates are enabled
>=20
> and/or
>=20
> 2. When the status of a host or service changes (i.e. a check is
> performed, a notification occurs, etc.)
>=20
> Check the log file to make sure the passive checks are being received
> and processed. I'm guessing that's where the problem lies - if the
> passive checks aren't being processed, there's no reason for Nagios
> to create the status file. Actually, that might not be totally
> correct. Nagios should create a status file immediately upon
> startup. Check your config file to make sure you don't have more
> than one status_file definition, etc.
Actually, I was having a problem with the passive checks. I didn't
realize that iptables was configured on this machine. Once that was
corrected (read 'disabled'), I am able to see nagios accept the passive
check (via strace), but nothing ever gets logged, nor is the status.dat
file ever created. As you mentioned, I would expect nagios to create the
status_file on startup regardless (even if it is with faked info). First
some more relevant config information --
[root@daginbox etc]# grep status_file nagios.cfg
status_file=3D/usr/local/nagios/var/status.dat
[root@daginbox etc]# grep passive nagios.cfg | grep -v "^#"
log_passive_checks=3D1
accept_passive_service_checks=3D1
accept_passive_host_checks=3D1
and these --
aggregate_status_updates=3D1
status_update_interval=3D10
(I have all the logging options enabled as well as compiled with
--enable-DEBUG0 and --enable-DEBUG1 now) Nagios.log only shows --
[1070473990] Nagios 2.0a1 starting... (PID=3D7131)
[1070473990] LOG VERSION: 2.0
[1070474026] Nagios 2.0a1 starting... (PID=3D7169)
[1070474026] LOG VERSION: 2.0
[1070474089] Nagios 2.0a1 starting... (PID=3D7263)
[1070474089] LOG VERSION: 2.0
[1070474138] Nagios 2.0a1 starting... (PID=3D7305)
[1070474138] LOG VERSION: 2.0
[1070474805] Nagios 2.0a1 starting... (PID=3D7565)
[1070474805] LOG VERSION: 2.0
Strace output of nagios reading passive check from command file --
[snip]
[pid 7169] open("/usr/local/nagios/var/retention.dat", O_RDONLY) =3D 4
[pid 7169] fstat64(4, {st_mode=3DS_IFREG|0644, st_size=3D0, ...}) =3D 0
[pid 7169] mmap2(NULL, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =3D 0xbeb47000
[pid 7169] read(4, "", 4096) =3D 0
[pid 7169] close(4) =3D 0
[pid 7169] munmap(0xbeb47000, 4096) =3D 0
[pid 7169] time([1070474033]) =3D 1070474033
[pid 7170] ) =3D 0 (Timeout)
[pid 7170] read(3, "[1070474024]
PROCESS_SERVICE_CHECK_RESULT;tnops-rhea-hs.rhea.tn.ena.net;WCCP;0;WCCP
OK: Total Packets Redirected: 30729337\n[1070474024]
PROCESS_SERVICE_CHECK_RESULT;tnops-scott-ecr-cache.scott.tn.ena.net;CACH
ING;0;HTTP ok: HTTP/1.0 =
200
OK - 1 second response time \n[1070474024]
PROCESS_SERVICE_CHECK_RESULT;tnops-rhea-alt.rhea.tn.ena.net;MULTI-EGRESS
;0;EGRESS CHECK OK =
All circuits up\n", 4096) =3D 262
[pid 7170] read(3, "", 4096) =3D 0
[pid 7170] select(0, NULL, NULL, NULL, {0, 500000}) =3D 0 (Timeout)
...[email truncated]...
