> Date: Fri, 01 Oct 2004 18:49:09 +0200
> From: Andreas Ericsson
> To: [email protected]
> Subject: Re: [Nagios-devel] nagios cvs and perfdata bug
> Yves Mettier wrote:
>> 1st bug :
> This was fixed yesterday.
>> 2nd bug :
>> Now, I consider that those files are defined.
>> If I start nagios with nothing in /opt/nagios/var (except archive/ and=
rw/), nagios
>> will
>> run, but nagios -d won't. Workaround : touch service-perfdata; touch h=
ost-perfdata
> Did you look up the reason? This has the 'feel' of a permission error o=
n
> the directory where the files should be stored.
Looks like, but probably not.
I first ran nagios with -d option. Problem.
Then I wanted to find the reason with strace. No problem, so I found noth=
ing. I just
noticed that it worked.
So I tried without the files (service-perfdata and host-perfdata), and wi=
thout -d : it
works.
I removed the files, and ran with -d : problem again.
I tested 2 or 3 times no files in var (and only archive and rw as directo=
ries), and
every time, it was the same thing : with -d it does not work, but without=
, it works. And
when the files exist, it works with -d.
BTW, nothing to do with this mail, but 2 colleagues of mine wrote an arti=
cle on Nagios
in Linux-France Magazine. And it is in first page !!! It should be there =
soon :
http://www.linuxmag-france.org/presenta ... amille=3D1
You can already see it there : http://213.41.125.3/revue.asp?revue=3DL927=
5
Where should I post a mail about this ? nagios-users@... ? nagios-announc=
e@... ?
Yves
--=20
- Homepage - http://ymettier.free.fr - http://www.logicacmg.com -
- GPG key - http://ymettier.free.fr/gpg.txt -
- Maitretarot - http://www.nongnu.org/maitretarot/ -
- GTKtalog - http://www.nongnu.org/gtktalog/ -
