> On Thu, 14 Oct 2004, Andreas Ericsson wrote:
>>>It seems to me that a {HOST,SERVICE}_STATUS event would only be fired
>>>after the check had happened, so that would imply that this would always
>>>be true if it was what you think it is. But that wouldn't make for a
>>>useful datapoint, so I think we are both confused.
>>I think Nagios just dumps all the data in the object struct to whatever
>>is listening in the receiving end and doesn't differ between if the data
>>passing takes place as the result of a timed event or as the result of
>>some sort of state change. I know modules can schedule data to be passed
>>at regular intervals as well as on events, so I guess that must be the
>>answer.
> Yes, but that still means that STATUS messages are still generated after a
> check, right?
Well, the message might be, but I think the internals are a bit
different. I think status events are just recorded in one and the same
host/service struct{}, and whenever something is to be passed to the
module, it dumps all of it instead of select parts. It's easier, I
suppose, and allows modules to do all that Nagios does, which is sort of
the general idea with modules.
>>>I don't understand.... but that's ok, I understand enough to know that I
>>>can ignore this for now.
>>>and reports.
>>I'm really interested in having a look at what you've done. Perhaps I
>>can improve it somehow and we could both benefit from it. Is it GPL'd or
>>do you have some proprietary copyright on it?
> Well, I have almost nothing yet except for a budding schema, a rough plan,
> and the go-ahead from my managers.
> more than happy to share the love. I would be estatic if I could get the
> code included in contrib/
If not, you can always open up your own project. It's really not that
difficult.
OP5 AB www.op5.se
Lead Developer
