Re: [Nagios-devel] Nagios Pluggins check_log new feature
On 01/27/2011 11:26 AM, Paul Green wrote:
> Hello,
> I would like to submit the attached changes for potential addition to the
> check_log script in the core pluggins. It adds the addition of an ignore
> option so that you can, for example, look for all "ERROR" within a log file
> (as per normal) but ignore "ProgramX" which is constantly whining and
> throwing errors when it shouldn't be. In my case a third party proprietary
> application in which the vendor neither care nor have the will to fix it.
> I've also taken the liberty to correct the comments at the top of the
> script to match the current command line options as well as the new ones.
Please re-send to [email protected], where the plugin
developers all hang out.
Thanks.
OP5 AB www.op5.se
on peace.
