Dear Folks,
I am keen to back port the 2.0 embedded Perl changes (to re-init the
Perl interpreter after 'n' checks, so that the size of the Nagios binary
does not grow without limit).
Is there any interest in a 1.3 release with (at a minimum) embedded Perl
changes ie from 2.0
1 re-init the Perl interpreter periodically
2 return Perl plugin results via perl_call_argv() instead of a /tmp file
3 p1.pl changes to return compilation faults with plugin output - no
more 'No output!' - and compile time options for logging at various
verbosity levels of Perl activity.
Both 2 and 3 have been used by me in a production hack of 1.2 for more
than 6 months without problems (other than the increase in memory use
that should be dealt with by patch 1).
Since I anticipate trouble (TM) with the thread support on *BSD systems
of Nag 2.0, there may be some point in maintaining the 1.x series.
I don't feel strongly about this since the 2.0 release looks extremely
good. Unfortunately *BSD systems may struggle with it.
BTW, for what it's worth, I have noticed a tendency to blame
the embedded Perl support for _any_ and _every_ trouble with Perl
plugins reported on Nag users.
I suspect that this blame is uniformed since it is much easier to write
a bad Perl plugin, or one that the embedded Perl support fails to
compile, than to identify actual problems in the embedded Perl code.
This is why for example that mod_perl provides an alternative to the
Registry module for CGIs that are so bad they cannot take advantage of
the normal mod_perl/Registry process of compile once and run many times.
The Perl component (ie p1.pl) of the embedded Perl support in Nagios
appear to be very similar to the mod_perl 1.x Apache::Registry.pm
module, a module that is not often heard described as 'buggy'.
Now I can well appreciate that I don't understand much, if anything
about embedding Perl, but the fact remains that
1 it works so well for me that I wouldn't consider a plain Nagios,
2 any criticsm about the embedded Perl support should probably take the
form of patches to this list, or silence on Nag users.
3 until an established Perl developer (ie someone with at least a
popular actively developed XS module [DougM where are you ?]) offers to
maintain this valuable facility, I will do my best to support it.
Yours sincerely.
Stanley Hopcroft
Network specialist, IT Infrastructure
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
