> Am Samstag, 28. Oktober 2006 20:04 schrieb Joerg Linge:
>> Am Samstag, 28. Oktober 2006 19:43 schrieb Joerg Linge:
>>> Hi Ethan, hi List
>>> the latest CVS HEAD does not compile with --enable-embedded-perl
>> Here is a possible Patch
>> "make all" returns no errors. I will check the function tomorrow
> Next try ....
> With the first patch Nagios will compile but i get a SIGSEV after 2 secounds
> Now the function works correct. ePN can now be disabled per plugin.
> Jörg
[snip]
Thanks Joerg! I modified the patch a bit to get rid of an unneeded
variable. Patch should be in CVS shortly.
Ethan Galstad,
Nagios Developer
Email: [email protected]
