Re: [Nagios-devel] timzones
Hi John,
Great patch!
One thing we really struggle with at my place of work is timezone
support. Ideally, we'd love to be able to run one instance of nagios,
supporting multiple timezones. I have seen people raise the issues &
concerns associated with adding timezone support into the scheduler,
particular for those timezones supporting daylight savings (ie; what
does the scheduler do when we skip foward an hour at beginning of DLS,
or skip backwards an hour at the end, how should times be displayed in
the CGI interface etc.). I think these can have acceptable solutions,
behaviour dependant on configuration options (ie. may be configured to
either run anything that may have been missed when forwarding an hour,
run a check twice when moving backwards an hour, or to ignore, display
timezone offset in CGIs). Your patch at least introduces partial
support, but IMHO would need to be configurable for these circumstances.
Thoughts, suggestions?
Regards,
Grant
John Lemon wrote:
> Hello Nick,
> I did a patch sometime ago to add timezone support to Nagios.
> Was for Nagios RC2 (so a bit old)
> http://article.gmane.org/gmane.network. ... h=timezone
> Patch worked OK, for a small number of timezones, but if you are using
> it just for contact checks it should work fine.(if it works with check
> Nagios release).
> I have done a re-code for better performance but it's not ready just it.
> Time permitting in the next week or so I will finish the new version.
> Is this sort of idea you were thinking of?
> Thanks
> John
> -----Original Message-----
> From: Nick [mailto:[email protected]]
> Sent: Friday, 13 March 2009 1:39 AM
> To: 'Nagios Developers List'
> Subject: Re: [Nagios-devel] timzones
> Its ok here I deal with most of Europe including Russia (11 times zone
> for
> 1 country) the USA and a few of others
> I'm not a programmer so was hoping those that can will read this and
> act
> Nick
> From: William Preston [mailto:[email protected]]
> Sent: Thursday, March 12, 2009 14:32
> To: Nagios Developers List
> On Mar12, 2009, at 11:09, Nick wrote:
>> We use FoxBox for sending out SMS's which is now built into Nagios
> If you mean the sendSMS.sh script from foxbox, then you can use it
> with NoMa too -
> the advantage is that you can log the failed sends and optionally
> escalate
> to Mail or Voice.
>> Lets hope setting time zones per contact relative to GMT with a
>> setting for
>> start/end DST can be added to Nagios in a future version.
> i agree it would be a handy feature, especially if checks could also
> be scheduled
> in localtime - I would use the standard system Timezone support though.
> Anyway, this is the developer list -> get coding and create a
> patch!!! ;-)
>> I counted up yesterday and I need over 100 different time periods
>> to cover
>> all the contacts, and that needs to be changed 2 times a year for DST.
> you make it sound so easy... in my experience it's a lot more complex
> - countries
> have a habit of changing aroung their DST changeovers on a whim.
> I'm thinking here particularly of Western Australia.
> William
> Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
> powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
> easily build your RIAs with Flex Builder, the Eclipse(TM)based
> development
> software that enables intelligent coding and step-through debugging.
> Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
> Nagios-devel mailing list
> [email protected]
...[email truncated]...
