I have two simple requests for the 3.5.0 release.=0A=0A* Since the Nagios d=
evelopers adopted some tool-enforced coding=0A standards a few releases ag=
o, those tools should be run before=0A every new release, to bring all rec=
ent changes up to the=0A claimed standards. In the nagios-3.5.0rc1.tar.gz=
release,=0A running the indent-all.sh script yields 77 files Unchanged=0A=
(which is what we want), but 20 files Formatted (out of spec=0A with reg=
ard to the coding standards). Please run this before=0A issuing the final=
3.5.0 release.=0A=0A* I would much prefer that the tarball unroll into a d=
irectory=0A named with the release level, such as nagios-3.5.0rc1/ or=0A =
nagios-3.5.0/ (for the final release), instead of a plain=0A nagios/ direc=
tory. This makes it a lot easier to deal with=0A multiple releases unroll=
ed in parallel, which we often want=0A in order to compare versions. This=
convention used to be=0A followed in older releases, at least through the=
nagios-3.2.3=0A release. Yes, of course, I can rename the directory myse=
lf,=0A but this convention is a lot cleaner (and followed by many if=0A n=
ot most other projects).=0A=0A--- On Thu, 2/28/13, Eric Stanley wrote:=0A=0A> From: Eric Stanley =0A> Subje=
ct: [Nagios-devel] Nagios Core 3.5.0rc1=0A> To: "Nagios Developers List" =0A> Date: Thursday, February 28, 2013, 3=
:59 AM=0A> Sorry for multiple release=0A> candidates, but I fixed two more =
issues with the CGIs that=0A> are very closely related to issues fixed in t=
he 3.4.5rc1=0A> tarball.=0A> =0A> The release has also been bumped to 3.5.0=
because of an ABI=0A> change. (It should have been bumped prior to 3.4.5rc=
1.) The=0A> downtime structure had a member added to help resolve the=0A> d=
owntime notification problem. This means that modules will=0A> need to be r=
ecompiled to use this version.=0A> =0A> You can download the 3.5.0rc1 tarba=
ll from http://sourceforge.net/projects/nagios/ ... gios-3.5.=
0/nagios-3.5.0rc1.tar.gz/download.=0A> =0A> Feel free to compile it and try=
it (on a test system,=0A> please). The 3.4.5 candidate did not generate mu=
ch feedback=0A> and I'm hoping no news is good news. The changes between=0A=
> 3.4.5rc1 and 3.5.0rc1 are relatively minor, so I don't plan=0A> to wait l=
ong until releasing 3.5.0.=0A> =0A> The complete changelog since 3.4.4 is a=
s follows:=0A> =0A> * Fixed bug #403: The "configuration" page of the webui=
=0A> doesn't use entity encoding when displaying the "command=0A> expansion=
" item (Eric Stanley)=0A> * Fixed bug #424: Nagios Core 3.4.4 seg fault (co=
re dump) on=0A> restart after removing config for running service (Eric=0A>=
Stanley)=0A> * Updated CGI utility functions to support UTF-8 characters=
=0A> (Eric Stanley)=0A> * Fixed bug where selecting Command Expansion from=
=0A> Configuration CGI page would display commands instead (Eric=0A> Stanle=
y)=0A> * Fixed bug #369: status.cgi crashes with segfault when=0A> there ar=
e german ulauts (=E4=F6=FC=DF) in the hostname or the=0A> servicename (Eric=
Stanley)=0A> * Fixed bug #418: Scheduled Downtime Notifications Resent On=
=0A> Nagios Restart/reload (Eric Stanley)=0A> =A0 =0A> =0A> -- =0A> Eric St=
anley=0A> ___=0A> Developer=0A> Nagios Enterprises, LLC=0A> Email:=A0 estan=
[email protected]=0A> Web:=A0 =A0 www.nagios.com=0A> =0A> =0A> ---------------=
---------------------------------------------------------------=0A> Everyon=
e hates slow websites. So do we.=0A> Make your web apps faster with AppDyna=
mics=0A> Download AppDynamics Lite for free today:=0A> http://p.sf.net/sfu/=
appdyn_d2d_feb=0A> _______________________________________________=0A> Nagi=
os-devel mailing list=0A> [email protected]=0A> https://li=
sts.sourceforge.net/lists/listinfo/nagios-devel=0A>
