$ host pluto.uk.nsynergy.com
pluto.uk.nsynergy.com has address 78.129.232.220
pluto.uk.nsynergy.com has address 78.129.232.223
Are both configured equal?
Saludos. Pablo.
-----Mensaje original-----
De: Martin Green [mailto:[email protected]]=20
Enviado el: S=E1bado, 03 de Enero de 2009 12:30 a.m.
Para: Nagios Developers List
Asunto: Re: [Nagios-devel] check_http inconsistent results
Hey Jon,
The machine is the DC.
M
-----Original Message-----
Sent: 02 January 2009 20:12
To: [email protected]
Subject: Re: [Nagios-devel] check_http inconsistent results
Martin,
Have you tried eliminating it being an issue with the plugin, and just
testing with wget or something similar?
Is the IIS server part of a domain? Have you tried checking the
security logs on the server to see if there are any odd entries there?
I do notice a substantial time difference between the execution of one
over the other. The successful run takes 0.69s, whilst the failed run
takes 6.49s, 10 times the execution time. If it is on a domain, could
it be having issues authenticating to a DC?
On Wed, 17 Dec 2008 23:19:43 +1100, Martin Green
wrote:
>No load balancing, it's just a plain old IIS server with SharePoint =
running
on it, configured to accept Basic auth.
>Auth details truncated for obvious reasons...
>root@Bungle:/usr/local/nagios/libexec# ./check_http -I
pluto.uk.nsynergy.com -a 123:123
>HTTP OK - HTTP/1.1 302 Redirect - 0.690 second response time
|time=3D0.690064s;;;0.000000 size=3D457B;;;0
>root@Bungle:/usr/local/nagios/libexec# ./check_http -H
>HTTP OK - HTTP/1.1 302 Redirect - 6.493 second response time
|time=3D6.493219s;;;0.000000 size=3D467B;;;0
>HTTP WARNING: HTTP/1.1 401 Unauthorized
>With -vvv root@Bungle:/usr/local/nagios/libexec# ./check_http -H
pluto.uk.nsynergy.com -a 123:123 -vvv
>GET / HTTP/1.0
>User-Agent: check_http/v2053 (nagios-plugins 1.4.13)
>Connection: close
>Host: pluto.uk.nsynergy.com
>Authorization: Basic bmFnaW9zOjB2M3IyWTB1
>http://pluto.uk.nsynergy.com:80/ is 224 characters
>STATUS: HTTP/1.1 401 Unauthorized
>**** HEADER ****
>Server: Microsoft-IIS/7.0
>WWW-Authenticate: NTLM
>X-Powered-By: ASP.NET
>MicrosoftSharePointTeamServices: 12.0.0.6219
>Date: Wed, 17 Dec 2008 12:05:11 GMT
>Connection: close
>Content-Length: 0
>**** CONTENT ****
>GET / HTTP/1.0
>Connection: close
>http://pluto.uk.nsynergy.com:80/ is 467 characters
>STATUS: HTTP/1.1 302 Redirect
>**** HEADER ****
>Content-Type: text/html; charset=3DUTF-8
>Location: http://pluto.uk.nsynergy.com/Pages/Default.aspx
>Date: Wed, 17 Dec 2008 12:05:18 GMT
>Connection: close
>Content-Length: 170
>**** CONTENT ****
>Document Moved
>Object MovedThis document may be found here
>HTTP OK - HTTP/1.1 302 Redirect - 0.239 second response time
|time=3D0.238797s;;;0.000000 size=3D467B;;;0
>That pattern will continue if I try again - whether it will be accepted =
or
not is somewhat arbritrary.
>M
>From: Thomas Guyot-Sionnest [mailto:[email protected]]
>Sent: 16 December 2008 19:43
>To: Nagios Developers List
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Martin Green wrote:
>> When I use basic auth with the -a argument, on one test I get 302
>> (fine), next I get 401 Unauth - testing repeatedly, I'll get =
...[email truncated]...
Original poster: on Angliss [mailto:[email protected]
