Re: [Nagios-devel] configuration directory
On Sep 3, 2013, at 5:34 PM, AL13N wrote:
> Op dinsdag 3 september 2013 17:22:32 schreef Andreas Ericsson:
>> On 2013-09-02 21:20, AL13N wrote:
>>> Hi,
>>>=20
>>> i'm a Mageia distribution packager, and i'm maintaining some event =
broker
>>> modules.
>>>=20
>>> since these are packaged seperately we're trying to get things to =
work
>>> out-of- the-box for our users, specifically adding event brokers in =
the
>>> configuration file for nagios.
>>>=20
>>> the problem we're facing is that: We don't want a nagios addon =
package to
>>> rewrite the configuration file itself. however, we would like to add =
the
>>> event broker (or other settings) and then reload/restart nagios.
>>>=20
>>> a beneficial thing would be a configuration directory (much like it =
exists
>>> with hosts and commands and stuff like that) but for the main nagios
>>> configuration file.
>>>=20
>>> and if while we're at it, to have multiple directories, where
>>> /usr/share/nagios/nagios.d/ has the "defaults" which can be =
overridden in
>>> /etc/nagios.d/ (for instance) (this is a convention that's growing =
in use)
>>>=20
>>> I can try to start making a patch for this, but i'm asking about =
this
>>> first, in order to find out if it makes a chance of getting =
accepted.
>>=20
>> Not only does it stand a chance of getting accepted; It's on the
>> roadmap. If you start working on it I'll help as much as I can and
>> I'm willing to accept less-than-awesome quality code, although I'll
>> polish such later if it turns out to be an issue.
>>=20
>> The only real requirement is that any "main" config file option
>> should be settable from any file in the dropdir.
>=20
>=20
> the idea i thought might be doable, would be to allow multiple -d =
options to=20
> nagios, and allow those to be a file or a directory.
>=20
> this would keep working:
>=20
> [ ]# /usr/sbin/nagios -d /etc/nagios/nagios.cfg
>=20
> and allow
>=20
> [ ]# /usr/sbin/nagios -d /usr/share/nagios/conf.d/ -d =
/etc/nagios/conf.d/
>=20
> to work too.
>=20
> internally, instead of one file, we'll have to have an array of =
files/dirs, so=20
> that reloading nagios would also expand the config files/dirs into =
files and=20
> parse them all in order...
>=20
>=20
remember too that -d is daemonize mode so probably need another option=85
Dan
