Re: [Nagios-devel] Custom Object Variables: Contrary to docs,
On 2010-08-28 15:59, Ethan Galstad egalstad-at-nagios.org |Lists/Send to=20
lists| wrote:
> Thanks for pointing this discrepancy out. Custom macros should be
> cleaned IMO, so I opted to update the docs instead. :-)
Could this please be a configuration option then? Sometimes there are=20
things that need to contain these characters.
- Windows services and shares sometimes actually have a $ in them
- Passwords can have special chars in them (that is even encouraged)
- The empty string is not representable because ' and " are illegal.
The reason I hunted the discrepancy down is that we have a need for the=20
special chars, e.g. for the things above.
Or, instead of simply removing them, would it be possible to=20
backslash-escape them? That way they won't be dangerous any longer.
Hoping for a config option or other good solution,
Peter
--=20
Peter Valdemar M=C3=B8rch
http://www.morch.com
Original poster: ?UTF-8?B?IlBldGVyIFZhbGRlbWFyIE3DuHJjaCAoTGlzdHMpIg==?
