Re: [Nagios-devel] Nagios 3.0b7 High CPU Load FreeBSD 6.2
------=_Part_30541_14607234.1197319801769
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Same box, same OS Nagios 2.10 does NOT have this problem
On 10/12/2007, Mike Brown wrote:
> So I guess we are at a loss :|
> netmon# ldd /usr/local/nagios/bin/nagios
> /usr/local/nagios/bin/nagios:
> libm.so.4 => /lib/libm.so.4 (0x280f4000)
> libpthread.so.2 => /usr/lib/libc_r.so.6 (0x2810a000)
> libc.so.6 => /lib/libc.so.6 (0x2812c000)
> netmon#
> On 10/12/2007, Andrew Ivanov wrote:
> > Hi Mike,
> > please use ldd utility to verify libmap.conf settings:
> > # ldd /path_to_/nagios
> > /path_to_/nagios:
> > libpthread.so.2 => /usr/lib/libc_r.so.6 (0x2cb19000)
> > if pthread will not be mapped to libc_r, then probably you need to set
> > correct path to nagios.
> > If mapping is ok, then I don't know what to suggest.
> > > here is the output from BEFORE the libmap.conf change
> > > 98795 nagios RET kse_release -1 errno 22 Invalid argument
> > > 98795 nagios CALL kse_release(0xbfbfe460)
> > > here is the output from AFTER the libmap.conf change
> > > 98688 nagios CALL kse_release(0xbfbfe490)
> > > 98688 nagios RET kse_release -1 errno 22 Invalid argument
> > It's strange that BEFORE pid is higher than AFTER, but nevertheless
> > output
> > is the same.
> > With best regards,
> > Andrew.
> > SF.Net email is sponsored by:
> > Check out the new SourceForge.net Marketplace.
> > It's the best place to buy or sell services for
> > just about anything Open Source.
> > http://sourceforge.net/services/buy/index.php
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
Content-Type: text/html; charset=ISO-8859-1
netmon# ldd /usr/local/nagios/bin/nagios/usr/local/nagios/bin/nagios:        libm.so.4 => /lib/libm.so.4 (0x280f4000)        libpthread.so.2 => /usr/lib/libc_r.so.6 (0x2810a000)        libc.so.6
=> /lib/libc.so.6 (0x2812c000)netmon#
On 10/12/2007, Andrew Ivanov <[email protected]
> wrote:
Hi Mike,please use ldd utility to verify libmap.conf settings:# ldd /path_to_/nagios/path_to_/nagios:
       ...       libpthread.so.2 => /usr/lib/libc_r.so.6 (0x2cb19000)       ...if pthread will not be mapped to libc_r, then probably you need to setcorrect path to nagios.If mapping is ok, then I don't know what to suggest.
> here is the output from BEFORE the libmap.conf change>  98795 nagios   RET   kse_release -1 errno 22 Invalid argument>  98795 nagios&nbsp
...[email truncated]...
