Hi Jason.
what you need to do is to modify xdata/xodtemplate.c,
common/objects.c, & common/objects.h
to add your extra fields.
to add extra macros you need to modify utils.c.. see
http://svn.webperf.org/WebSVN/diff.php? ... ev=62&sc=1
for an example of how I did it
On Fri, 6 Aug 2004 10:51:01 -0700, Jason Martin wrote:
> On Fri, Aug 06, 2004 at 10:45:04AM -0700, Jason Martin wrote:
> > On Fri, Aug 06, 2004 at 12:30:31PM -0500, Marc Powell wrote:
> > > An alternative would be to alter your notification command to suit your
> > > specific needs and grab that extra info from a flat file, db or other
> > > data source before sending the alert.
> > I thought about that, but the problem is that I'd have to
> > maintain two seperate config files. It would be much easier to
> > maintain syncronization if they stayed in the same file.
> Another thought is that only one of the two sets of data would
> benefit from Nagios's templating, so the 'other' file would not
> even correspond 1:1 with the Nagios file.
> -Jason Martin
> If voting changed anything, they'd make it illegal.
> This message is PGP/MIME signed.
