Re: [Nagios-devel] nagios 2.4 exits prematurely if /usr/sbin/p1.pl
Marc Haber wrote:
> Hi,
> If nagios 2.4 does not find p1.pl, it prints a warning "Can't open
> perl script "/usr/sbin/p1.pl": No such file or directory" and starts.
> As soon as the first perl plugin is called, nagios exits with an exit
> code of 254 and logs a SIGSEGV to nagios.log. No core dump.
> In my opinion, this is a bug which should be fixed.
> Greetings
> Marc
Thanks for the note on this. I'm committing a patch that will cause
Nagios to exit with an error during the embedded Perl initialization
code if the p1.pl file doesn't exist. That should fix the problem.
Ethan Galstad,
Nagios Developer
Email: [email protected]
