[Nagios-devel] Deprication of parallelize directive and RFE.
In:
http://nagios.cvs.sourceforge.net/*chec ... tsnew.html
is this blurb:
# Object Definitions:
* The parallelize directive in service definitions is now deprecated and no longer used. All service checks are run in parallel in Nagios 3.
One thing that I have had to use parallelize for is when service
checks use a shared resource. E.G.
ConsoleLoginTest
ConsoleErrorsCheck
that I wrote both connected to a given port on a cycaldes switch, and
executed two different commands to the gear on the other side. The two
couldn't run at the same time without conflicting. I am wondering if
the parallelize directive should be replaced with something like:
description ConsoleLoginTest
NoExecuteWith :ConsoleErrorsCheck
or more generally:
NoExecuteWith hostname:ConsoleErrorsCheck
to prevent conflicting tests from being scheduled at the same time?
In my case setting the parrallelize_check directive to 0 for those two
services didn't work the way I wanted in some way so I had to write
the local login in the tests themselves which was a pain.
I think being able to specify the execution exclusions in a similar
way to specifying dependencies would be a nice feature.
-- rouilj
John Rouillard
My employers don't acknowledge my existence much less my opinions.
