Re: [Nagios-devel] Nagios and Gearman - huge environment
--0016e6d99d1dd8c70a04ab411747
Content-Type: text/plain; charset=ISO-8859-1
Hi Sven. Thank you again. I=B4m pretty sure that my check interval is 15 mi=
n,
for both, hosts and services. I=B4ve set this in the templates.cfg file (se=
e
below). I sending too the nagiostats output. I agree with you that if we
divide 100 k checks / 15 min ~ 111 checks/sec, but the problem is that
Nagios does not make these checks smoothly during the time. Thats the
problem.
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
templates.cfg
name generic-host
check_interval 15
name generic-service
normal_check_interval 15
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
nagiostats output
Nagios Stats 3.2.3
Copyright (c) 2003-2008 Ethan Galstad (www.nagios.org)
Last Modified: 10-03-2010
License: GPL
CURRENT STATUS DATA
Status File: /usr/local/nagios/var/status.dat
Status File Age: 0d 0h 0m 17s
Status File Version: 3.2.3
Program Running Time: 0d 17h 43m 2s
Nagios PID: 18854
Used/High/Total Command Buffers: 0 / 0 / 4096
Total Services: 68206
Services Checked: 68206
Services Scheduled: 68206
Services Actively Checked: 68206
Services Passively Checked: 0
Total Service State Change: 0.000 / 43.880 / 2.774 %
Active Service Latency: 40.671 / 503.137 / 234.919 sec
Active Service Execution Time: 0.003 / 24.737 / 2.527 sec
Active Service State Change: 0.000 / 43.880 / 2.774 %
Active Services Last 1/5/15/60 min: 0 / 2897 / 35932 / 68206
Passive Service Latency: 0.000 / 0.000 / 0.000 sec
Passive Service State Change: 0.000 / 0.000 / 0.000 %
Passive Services Last 1/5/15/60 min: 0 / 0 / 0 / 0
Services Ok/Warn/Unk/Crit: 46943 / 56 / 7660 / 13547
Services Flapping: 980
Services In Downtime: 0
Total Hosts: 34103
Hosts Checked: 34103
Hosts Scheduled: 34103
Hosts Actively Checked: 34103
Host Passively Checked: 0
Total Host State Change: 0.000 / 63.820 / 2.598 %
Active Host Latency: 0.000 / 474.337 / 247.944 sec
Active Host Execution Time: 0.000 / 20.354 / 2.033 sec
Active Host State Change: 0.000 / 63.820 / 2.598 %
Active Hosts Last 1/5/15/60 min: 0 / 5936 / 29437 / 34103
Passive Host Latency: 0.000 / 0.000 / 0.000 sec
Passive Host State Change: 0.000 / 0.000 / 0.000 %
Passive Hosts Last 1/5/15/60 min: 0 / 0 / 0 / 0
Hosts Up/Down/Unreach: 23591 / 10512 / 0
Hosts Flapping: 597
Hosts In Downtime: 0
Active Host Checks Last 1/5/15 min: 3 / 89 / 209
Scheduled: 0 / 0 / 0
On-demand: 3 / 89 / 209
Parallel: 0 / 0 / 0
Serial: 0 / 0 / 0
Cached: 3 / 89 / 209
Passive Host Checks Last 1/5/15 min: 0 / 0 / 0
Active Service Checks Last 1/5/15 min: 0 / 0 / 0
On-demand: 0 / 0 / 0
Cached: 0 / 0 / 0
Passive Service Checks Last 1/5/15 min: 0 / 0 / 0
External Commands Last 1/5/15 min: 0 / 0 / 0
On Tue, Aug 23, 2011 at 6:14 PM, Sven Nierlein wro=
te:
> On 8/23/11 22:21, Rodney Ramos wrote:
> > When I=B4ve changed the max_concurrent_checks from "0" to "200", nagios
> process fell down to 30/50%. However, the latency increased a lot, g
...[email truncated]...
