Re: [Nagios-devel] Embedded Perl feature request
You beat me to it. I was just going to get to that tonight. :-)
On 3 Dec 2002 at 10:46, Russell Scibetti wrote:
> I see that Ethan has done some checkins regarding the embedded perl
> features. I wanted to add one suggestion that I emailed out once
> previously but had no response.
> The path to p1.pl (the file embedded perl appears to use) is hardcoded
> in locations.h after you run configure. If you ever want to move
> anything around, have multiple instances with separate p1.pl files, etc,
> you would need to re-configure and re-make, so it's not very portable.
> Can you add a line to the nagios.cfg to specifiy where the p1.pl file
> lives and have Nagios read it from the cfg instead of the hardcoded
> value in locations.h. Thanks.
> -Russell
> Russell Scibetti
> Quadrix Solutions, Inc.
> http://www.quadrix.com
> (732) 235-2335, ext. 7038
> This SF.net email is sponsored by: Microsoft Visual Studio.NET
> comprehensive development tool, built to increase your
> productivity. Try a free online hosted session at:
> http://ads.sourceforge.net/cgi-bin/redi ... micr0003en
> Nagios-devel mailing list
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
