Thanks -
I'll get these applied and include a .cvsignore file with the
suggested entries.
On 8 Aug 2004 at 8:19, Ian Holsman wrote:
> also..
> have you guys considered using a .cvsignore file?
> adding this to the cgi directory will make diffs/updates a bit more
> managable.
> .cvsignore:
> *.cgi
> Makefile
> Index: cgiutils.c
> RCS file: /cvsroot/nagios/nagios/cgi/cgiutils.c,v retrieving revision
> 1.35 diff -u -r1.35 cgiutils.c --- cgiutils.c 10 Feb 2004 04:18:27
> -0000 1.35 +++ cgiutils.c 7 Aug 2004 21:10:47 -0000 @@ -72,14
> +72,14 @@
> extern int enable_failure_prediction;
> extern int process_performance_data;
> -time_t last_command_check=0L;
> +extern time_t last_command_check;
> int check_external_commands=0;
> int date_format=DATE_FORMAT_US;
> int log_rotation_method=LOG_ROTATION_NONE;
> -time_t last_log_rotation=0L;
> +extern time_t last_log_rotation;
> time_t this_scheduled_log_rotation=0L;
> time_t last_scheduled_log_rotation=0L;
> Index: statuswrl.c
> RCS file: /cvsroot/nagios/nagios/cgi/statuswrl.c,v retrieving revision
> 1.16 diff -u -r1.16 statuswrl.c --- statuswrl.c 15 Aug 2003 01:34:09
> -0000 1.16 +++ statuswrl.c 7 Aug 2004 21:10:47 -0000 @@ -88,7
> +88,7 @@
> void calculate_circular_coords(void);
> void calculate_circular_layer_coords(host *,double,double,int,int);
> -char url_logo_images_path[MAX_FILENAME_LENGTH];
> +extern char *url_logo_images_path;
> authdata current_authdata;
> This SF.Net email is sponsored by OSTG. Have you noticed the changes
> on Linux.com, ITManagersJournal and NewsForge in the past few weeks?
> Now, one more big change to announce. We are now OSTG- Open Source
> Technology Group. Come see the changes on the new OSTG site.
> www.ostg.com _______________________________________________
> Nagios-devel mailing list [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
