[Nagios-devel] Nagios3 Fix for
Hi List, hi Ethan,
after playing lots with perfdata commands and so on....
There is a small (I guess) copy & paste error in xdata/xpddefault.c.
######## FIX #########
diff -Naur nagios3-clean/xdata/xpddefault.c nagios3/xdata/xpddefault.c
--- nagios3-clean/xdata/xpddefault.c 2007-02-24 12:09:22.000000000 +0100
+++ nagios3/xdata/xpddefault.c 2007-03-01 14:23:16.000000000 +0100
@@ -297,7 +297,7 @@
/* save the command pointer for later */
xpddefault_host_perfdata_file_processing_command_ptr=temp_command;
xpddefault_service_perfdata_file_processing_command_ptr=temp_command;
/* periodically process the host perfdata file */
Kind Regards,
Hendrik
