Re: [Nagios-devel] 2.0a1 SIGSEGV
Dear devs,
I'm sorry for the previous noise. Thanks to Mr. Hopcroft, I managed to
get some useful info out of gdb. Or at least it is useful for you. Here
is the output:
[root@gcclo77 bin]# gdb nagios
GNU gdb Red Hat Linux (6.0post-0.20040223.20rh)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "i386-redhat-linux-gnu"...(no debugging
symbols found)...Using host libthread_db library
"/lib/tls/libthread_db.so.1".
(gdb) set args /usr/local/nagios/etc/nagios.cfg
(gdb) r
Starting program: /usr/local/nagios/bin/nagios
(no debugging symbols found)...(no debugging symbols found)...(no
debugging symbols found)...(no debugging symbols found)...[Thread
debugging using libthread_db enabled]
[New Thread -1220216704 (LWP 26021)]
Nagios 2.0a1
Copyright (c) 1999-2004 Ethan Galstad ([email protected])
Last Modified: 11-18-2003
License: GPL
(no debugging symbols found)...Nagios 2.0a1 starting... (PID=26021)
[New Thread -1220326480 (LWP 26038)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1220216704 (LWP 26021)]
0xb747ea6a in __strtol_internal () from /lib/tls/libc.so.6
(gdb) list
No symbol table is loaded. Use the "file" command.
(gdb) info stack
#0 0xb747ea6a in __strtol_internal () from /lib/tls/libc.so.6
#1 0x0806c49a in xrddefault_read_state_information ()
#2 0x08069d37 in read_initial_state_information ()
#3 0x08052413 in main ()
(gdb) info stack
(gdb) print deviceId
(gdb) bt full
No symbol table info available.
(gdb)
Can anyone point me to a way forward now?
Tom
Tom DE BLENDE (GCC) wrote:
> Hi Stanley,
> CC List
> I'm sorry if I don't understand what you want me to do. But if I
> understand correctly, you want me to recompile Nagios with -g option
> to gcc. But if I check the files you pointed me to, it looks like it
> allready was the case:
> [root@gcclo77 nagios-cvs]# grep CFLAGS Makefile
> CFLAGS=-g -O2 -DHAVE_CONFIG_H
> [root@gcclo77 nagios-cvs]# grep CFLAGS Makefile.in
> CFLAGS=@CFLAGS@ @DEFS@
> Environment is Centos 3.1 fully patched (RHEL 3):
> [root@gcclo77 nagios-cvs]# gcc -v
> Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/specs
> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> --infodir=/usr/share/info --enable-shared --enable-threads=posix
> --disable-checking --with-system-zlib --enable-__cxa_atexit
> --host=i386-redhat-linux
> Thread model: posix
> gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-39)
> [root@gcclo77 nagios-cvs]# uname -a
> Linux gcclo77 2.4.21-15.0.4.ELsmp #1 SMP Wed Aug 4 00:52:17 EDT 2004
> i686 i686 i386 GNU/Linux
> [root@gcclo77 nagios-cvs]# cat /proc/version
> Linux version 2.4.21-15.0.4.ELsmp (skvidal@el) (gcc version 3.2.3
> 20030502 (Red Hat Linux 3.2.3-34)) #1 SMP Wed Aug 4 00:52:17 EDT 2004
> Kind regards,
> Tom
> Stanley Hopcroft wrote:
>> Dear Tom,
>> I am writing to thank you for your letter and say,
>> On Fri, Sep 03, 2004 at 10:25:30AM +0200, Tom DE BLENDE (GCC) wrote:
>> '(no debugging symbols found)' is fatal since it means gdb can't
>> relate the fault in the text (binary) with the source.
>> I
...[email truncated]...
