------_=_NextPart_001_01CBDCE5.FBD540B5
Content-Type: text/plain;
charset="us-ascii"
Doesn't this create potential problem if you just do a normal start with
errors and not a restart? i.e. verify -> stop -> update configs ->
start -> die ?
=20
Dan
=20
From: SCHAER Frederic [mailto:[email protected]]=20
Sent: Monday, March 07, 2011 10:30 AM
To: [email protected]
Subject: [Nagios-devel] nagios startup script patch
=20
=20
Attached is a patch that intends to remove duplicate configuration
checks when (re)starting nagios.
Especially, this divides by three nagios restart time for large
configurations since the restart sequence is no more "verify - stop -
verify - start + nagios paths check", but only "verify - stop - start
without checking paths" .
=20
Without patch, and because of circular dependencies checks, my nagios is
taking 15 minutes to restart:
=20
# time service nagios restart
Running configuration check...done.
Stopping nagios: ...done.
Starting nagios: done.
=20
real 15m40.751s
user 15m24.449s
sys 0m1.388s
=20
=20
With this simple patch :=20
Stopping nagios: ..done.
=20
real 5m2.680s
user 4m52.048s
sys 0m0.820s
=20
I hope this gets included in the code...
Cheers,
=20
Frederic Schaer
Content-Type: text/html;
charset="us-ascii"
Doesn’t this create potential problem if =
you just do a normal start with errors and not a restart? =
i.e. verify -> stop -> update configs -> start =
-> die ? Dan <div =
style=3D'border:none;border-top:solid #B5C4DF 1.0pt;padding:3.0pt 0in =
0in 0in
...[email truncated]...
Original poster: CHAER Frederic [mailto:[email protected]]=2
