[Nagios-devel] NDO big perfdata bug?
--------------090504090300000002040900
Currently I'm testing injecting big results into Nagios via a new
program called nrd (Nagios Result Distributor) (I posted a while ago on
this list, announcing it as nsca2).
Currently I'm getting the results into Nagios fine, but ndo seems to
have a bad time with big perfdata... The Nagios screens show all the
perfdata correctly, but the results don't appear in the NDO db.
I activate debugging in NDO, and never see an INSERT with lots of
perfdata. I've tracked down the problem to the following:
- the ndo.dat file seems to get the data messed up:
- reading through the code, it looks like every entry in the ndo.dat
would finish in 999 (NDO_API_ENDDATA)
- the perfdata entry 99 (NDO_API_PERFDATA) for "206:" seems to have
a mix of data in it (starts like result "213", until you get another
NDO_API_PERFDATA section, and at the end of the line you get a 999 (with
no "\n" before it).
- I attach a test.dat file that is a capture of the ndo.dat file so
you can examine it.
- I attach the script that is causing this: check_big_perfdata.pl
I would expect to see the 500 perfdata entries that the big_perfdata
check generates (as the Nagios status screens show them without problems)
Looking around in the code, to find a possible cause, I think I found a
small bug in io.c, also
ndo_unescape_buffer:
if (buffer[x+1]=='\t'){
i think should be
if (buffer[x+1]=='t'){
but I think this is unrelated to the big perfdata problem.
Any thoughs on why NDO is "eating up" the perfdata?
Cheers,
Jose Luis Martinez
[email protected]
name="test.dat"
Content-Disposition: inline;
filename="test.dat"
HELLO
PROTOCOL: 2
AGENT: NDOMOD
AGENTVERSION: 1.4b7
STARTTIME: 1254090868
DISPOSITION: REALTIME
CONNECTION: FILE
CONNECTTYPE: INITIAL
INSTANCENAME: default
STARTDATADUMP
206:
1=3D701
2=3D0
3=3D0
4=3D1254090871.88609
53=3Dcode.google.com
114=3DBig perf check 500
12=3D1
25=3D1
76=3D3
121=3D1
118=3D0
123=3D60
127=3D
13=3D
14=3D
117=3D1254090410.577764
33=3D1254090410.577764
32=3D0
42=3D0.00000
71=3D460.57641
110=3D0
95=3DBIG_PERFDATA OK - Im OK
99=3Dperf_1=3D1;; perf_2=3D2;; perf_3=3D3;; perf_4=3D4;; perf_5=3D5;; per=
f_6=3D6;; perf_7=3D7;; perf_8=3D8;; perf_9=3D9;; perf_10=3D10;; perf_11=3D=
11;; perf_12=3D12;; perf_13=3D13;; perf_14=3D14;; perf_15=3D15;; perf_16=3D=
16;; perf_17=3D17;; perf_18=3D18;; perf_19=3D19;; perf_20=3D20;; perf_21=3D=
21;; perf_22=3D22;; perf_23=3D23;; perf_24=3D24;; perf_25=3D25;; perf_26=3D=
26;; perf_27=3D27;; perf_28=3D28;; perf_29=3D29;; perf_30=3D30;; perf_31=3D=
31;; perf_32=3D32;; perf_33=3D33;; perf_34=3D34;; perf_35=3D35;; perf_36=3D=
36;; perf_37=3D37;; perf_38=3D38;; perf_39=3D39;; perf_40=3D40;; perf_41=3D=
41;; perf_42=3D42;; perf_43=3D43;; perf_44=3D44;; perf_45=3D45;; perf_46=3D=
46;; perf_47=3D47;; perf_48=3D48;; perf_49=3D49;; perf_50=3D50;; perf_51=3D=
51;; perf_52=3D52;; perf_53=3D53;; perf_54=3D54;; perf_55=3D55;; perf_56=3D=
56;; perf_57=3D57;; perf_58=3D58;; perf_59=3D59;; perf_60=3D60;; perf_61=3D=
61;; perf_62=3D62;; perf_63=3D63;; perf_64=3D64;; perf_65=3D65;; perf_66=3D=
66;; perf_67=3D67;; perf_68=3D68;; perf_69=3D69;; perf_70=3D70;; perf_71=3D=
71;; perf_72=3D72;; perf_73=3D73;; perf_74=3D74;; perf_75=3D75;; perf_76=3D=
76;; perf_77=3D77;; perf_78=3D78;; perf_79=3D79;; perf_80=3D80;; perf_81=3D=
81;; perf_82=3D82;; perf_83=3D83;; perf_84=3D84;; perf_85=3D85;; perf_86=3D=
86;; perf_87=3D87;; perf_88=3D88;; perf_89=3D89;; perf_90=3D90;; perf_91=3D=
91;; perf_92=3D92;; perf_93=3D93;; perf_94=3D94;; perf_95=3D95;; perf_96=3D=
96;; perf_97=3D97;; perf_98=3D98;; perf_99=3D99;; perf_100=3D100;; perf_1=
01=3D101;; perf_102=3D102;; perf_103=3D103;; perf_104=3D104;; perf_105=3D=
105;; perf_106=3D106;; perf_107=3D107;; perf_108=3D108;; perf_109=3D109;;=
perf_110=3D110;; perf_111=3D111;; perf_112=3D112;; perf_113=3D
...[email truncated]...
