Hash: SHA1
On 11-01-27 10:31 PM, Tevfik Karagulle wrote:
> Hi,
> Sounds good. I have already made some optimizations and it seems to work
> as expected.
> Updated patch is now a part of the recently released Nagwin 1.0.1.
> Source code is also available from Nagwin download address.
> I will wait one week or so to see how it performs. As you suggested, it
> is better to implement it as a feature.
> Regarding documentation, what are your expectations
> or guidelines that can help ?
For now, a "CYGWIN" file in the root dir where we can add instructions
on building/using under cygwin will do. I'll make it cleat this is
experimental...
Your command pipe replacement should be documented in enough details for
someone comfortable with Nagios to be able to use it (i.e. control
Nagios with it) without reading the code.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk1CPvsACgkQ6dZ+Kt5BchZlxQCgsIBxrlUB1xCBJe2jl+vTAEWa
+zIAn0NsuRLLD8ymu/8PSPLLXXUA9DOX
=DQfo
-----END PGP SIGNATURE-----
