Hello all,
this is my first time posting to this list. I'm trying to create a
custom plugin that monitors an applications log file in real time.
I'm unclear as to whether or not I can do this explicitly with a plugin
(the real time aspect).
I'm running a Nagios 2.x management console that's getting data from a
production Linux system running nrpe. The real time monitoring needs to
run on the production box.
I'm trying to create the plugin (using Perl as my language) thus;
1. Create a daemon that actually monitors the log file.
2. On a specific event, the daemon will write status information to a
data file.
3. The plugin will read the data file at a specified interval and send
it back through the nrpe daemon to the nagios console.
Is this the right way to go about it? I don't quite see how to merge
the steps so that the plugin does all of the functionality in one
program. Since the code needs to run in real time, for example, I can't
output any of the Nagios error codes since the daemon never quits unless
the entire system goes down.
Thanks for your help.
Braun Brelin
OpenApp
