Thanks for the report, Phil.
I'm having a hard time guessing what might have broken that between
3.4.4 and now. I did a quick test using check_dummy and I don't see the
issue.
Are you running 3.4.4? If not, what version are you running where it
works correctly? Also, where do you see the broken URL?
Could you send me the output of the plugin(s) run from the command line?
Eric
On 3/5/13 11:53 AM, Randal, Phil wrote:
> 3.5.0rc1 breaks check_openmanage output (and check_esxi_hardware.py output in the same way)
> A link which should be, for example,
> http://support.dell.com/support/edocs/systems/peR815/
> gets mangled into something liek
> http:///nagios/cgi-bin/"http://support.dell.com/support/edocs/systems/peR815/"
> Cheers,
> Phil
> -----Original Message-----
> From: Eric Stanley [mailto:[email protected]]
> Sent: 28 February 2013 11:59
> To: Nagios Developers List
> Subject: [Nagios-devel] Nagios Core 3.5.0rc1
> Sorry for multiple release candidates, but I fixed two more issues with the CGIs that are very closely related to issues fixed in the 3.4.5rc1 tarball.
> The release has also been bumped to 3.5.0 because of an ABI change. (It should have been bumped prior to 3.4.5rc1.) The downtime structure had a member added to help resolve the downtime notification problem. This means that modules will need to be recompiled to use this version.
> You can download the 3.5.0rc1 tarball from http://sourceforge.net/projects/nagios/ ... z/download.
> Feel free to compile it and try it (on a test system, please). The 3.4.5 candidate did not generate much feedback and I'm hoping no news is good news. The changes between 3.4.5rc1 and 3.5.0rc1 are relatively minor, so I don't plan to wait long until releasing 3.5.0.
> The complete changelog since 3.4.4 is as follows:
> * Fixed bug #403: The "configuration" page of the webui doesn't use entity encoding when displaying the "command expansion" item (Eric Stanley)
> * Fixed bug #424: Nagios Core 3.4.4 seg fault (core dump) on restart after removing config for running service (Eric Stanley)
> * Updated CGI utility functions to support UTF-8 characters (Eric Stanley)
> * Fixed bug where selecting Command Expansion from Configuration CGI page would display commands instead (Eric Stanley)
> * Fixed bug #369: status.cgi crashes with segfault when there are german ulauts (äöüß) in the hostname or the servicename (Eric Stanley)
> * Fixed bug #418: Scheduled Downtime Notifications Resent On Nagios Restart/reload (Eric Stanley)
> Eric Stanley
> ___
> Developer
> Nagios Enterprises, LLC
> Email: [email protected]
> Web: www.nagios.com
> Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics
> Download AppDynamics Lite for free today:
> http://p.sf.net/sfu/appdyn_d2d_feb
> Nagios-devel mailing list
> [email protected]
> “Any opinion expressed in this e-mail or any attached files are those of the individual and not necessarily those of Hoople Ltd. You should be aware that Hoople Ltd. monitors its email service. This e-mail and any attached files are confidential and intended solely for the use of the addressee. This communication may contain material protected by law from being passed on. If you are not the intended recipient and have received this e-mail in error, you are advised that any use, dissemination, forwarding, printing or copying of this e-mail is strictly prohibited. If you have received this e-mail in error please contact the sender immediately and destroy all copies of it.
...[email truncated]...
