Ton Voon wrote:
> On 11 Aug 2009, at 09:30, Andreas Ericsson wrote:
>> Ton Voon wrote:
>>> On 31 Jul 2009, at 16:10, Ethan Galstad wrote:
>>> Andreas writes:
>>>> Why use the exclamation mark at all? It's quite straightforward to
>>>> parse
>>>> shell-style quoting into arguments, and that way users can just
>>>> cut-n-paste
>>>> the commands to verify that they work (assuming they replace the
>>>> macros,
>>>> that is).
>>> That's wrong. You use execve to avoid the shell quoting and to pass
>>> in
>>> arguments "as-is" to the plugin without interpretation at the shell
>>> level.
>> I'm well aware of that, but hand-parsing it inside Nagios would not be
>> difficult, assuming we can still pass commands with sub-shells to the
>> shell for execution.
> I'm not sure what you mean here. Can you give an example?
I mean that we can get rid of roughly 35-40% of the load from Nagios by
avoiding the extra fork()+execve() the shell causes by simply parsing
the command ourselves. However, we shouldn't bother with commands that
include sub-shells or pipes, so a command such as this:
check_http -H example.com -p $(cat example.com.port) | grep -e expr
had better be handed over to the shell instead of us adding bidirectional
communication pipes and subcommand argument substitution inside Nagios.
OP5 AB www.op5.se
on peace.
