[Nagios-devel] passive service freshness with nagios restart
I use passive checks for several purposes, but I'd like to start using
them as a daily heartbeat. The problem is that my nagios server restarts
at least once a day and the freshness timeout is always reset to the
restart time instead of the last time a passive check was sent. It looks
like the behaviour I would like was present in older versions, but
changed:
base/checks.c:
/* CHANGED 02/25/06 SG - passive checks also become stale, so remove dependence on active check logic */
if(temp_service->has_been_checked==FALSE || program_start>temp_service->last_check)
expiration_time=(time_t)(program_start+freshness_threshold);
The freshness example given in the docs (freshness.html) is a daily
heartbeat. It appears that the above change makes a heartbeat impossible
if the freshness_threshold is ever longer than a reboot cycle.
I think the only way to fix this is to back-out the change (unlikely) or
add yet another config file option - something like freshness_restart -
and include it in the checks.c expiration_time logic.
Unless I'm missing something. Has anyone else run into this problem or
found a different work around?
Michelle
