Re: [Nagios-devel] NSCA error with --single and aggregate writes
Thanks - patch will be in CVS soon.
Thomas Guyot-Sionnest wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Ton Voon wrote:
>> Hi Ethan,
>> We've found a problem with NSCA when aggregate writes are enabled and
>> NSCA starts writing to the command file before it gets created.
>> Details here: http://altinity.blogs.com/dotorg/2008/0 ... egate.html
> Alternatively, Nagios could leave the pipe here and have nsca open the
> file in non-blocking read-write - it will then be able to fill up the
> pipe and Nagios will get the queued commands when it starts up. On write
> failures (pipe full) the dump file could be used. This would be the
> preferred method to avoid data loss.
> That's pretty much the same as host/service_perfdata_file_mode=p in
> Nagios 3 with a daemon like OCP_Daemon to get the data, but the other
> way round.
> Thomas
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
