Re: [Nagios-devel] several host notifications for 1 host
Am Mittwoch, 23. Mai 2007 16:31 schrieb Thomas Guyot-Sionnest:
> > -----Original Message-----
> > From: [email protected] [mailto:nagios-devel-
> > [email protected]] On Behalf Of Joerg Linge
> > Sent: May 23, 2007 9:24
> > To: Nagios Developers List
> > Subject: Re: [Nagios-devel] several host notifications for 1 host
> >=20
> > Am Mittwoch, 23. Mai 2007 14:55 schrieb Markus Blum:
> > > Hello,
> > > i get several notifications after a host went down even
> > notification_interval is defined as 0. It seems to be related to service
> > checks on these host because other hosts, without service checks, work
> > fine. I know service checks will cause a host check but even then there
> > shouldn't be a notification before the host check returns a hard stat=
e,
> > right ?
> >=20
> > Hi Markus,
> >=20
> > i think you are talking about Nagios 3.0a4 right ?
> > The same Situation on my system running nagios 3.0a4 CVS 2007-05-23
> >=20
> > Host Down Notifications are sent on HARD and SOFT states.
>=20
> According to Nagios documentation both 2.x and 3.x:
>=20
> notification_interval: This directive is used to define the number of "t=
ime
> units" to wait before re-notifying a contact that this server is still do=
wn
> or unreachable. Unless you've changed the interval_length directive from =
the
> default value of 60, this number will mean minutes. If you set this value=
to
> 0, Nagios will not re-notify contacts about problems for this host - only
> one problem notification will be sent out.
Yes thats right. Notification interval and is_volatile are both set to 0 fo=
r this Host
> Looks like this is a bug... Does it keep notifying after in enters a HARD
> state? If no, then setting "max_check_attempts 1" will fix your problem.
> SOFT states on service check failures are sending notifications anyways.
We are talking about HOST notifications.
Soft Host States are a new 3.x feature.
No, max_check_attempts is set to 10. No more notifications if the =A0
HARD state is reached.
I have turned on debug level 32 for notifications and every SOFT =A0
state results in a notification.
DEBUG Log:
1179983462.267951:032.0] ** Host Notification Attempt ** Host: 'kassel-srv3=
=2D3', Type: 0, Current State: 1, Last Notification: Thu Jan 1 01:00:00 19=
70
[1179983462.267992:032.0] Notification viability test passed.
[1179983462.268006:032.1] Current notification number: 1
[1179983462.268019:032.2] Creating list of contacts to be notified.
[1179983462.268033:032.1] Host notification will NOT be escalated.
[1179983462.268047:032.2] Adding contact 'nagiosadmin' to notification list.
[1179983462.268433:032.2] ** Checking host notification viability for conta=
ct 'nagiosadmin'...
[1179983462.268464:032.2] ** Host notification viability for contact 'nagio=
sadmin' PASSED.
[1179983462.268478:032.2] ** Notifying contact 'nagiosadmin'
[1179983462.268577:032.2] Raw Command: /usr/bin/printf "%b" "***** Nagios *=
[1179983462.268591:032.2] Processed Command: /usr/bin/printf "%b" "***** Na=
gios ***** ....
[1179983462.327568:032.2] Calculating next valid notification time...
[1179983462.327610:032.2] Default interval: 16384
[1179983462.327626:032.2] Interval used for calculating next valid notifica=
tion time: 0.000000
[1179983462.327658:032.0] No contacts were notified. Next possible notific=
ation time: Thu May 24 07:11:02 2007
[1179983462.327672:032.0] 1 contacts were notified.
[1179983582.127427:032.0] ** Host Notification Attempt ** Host: 'kassel-srv=
3-3', Type: 0, Current State: 1, Last Notification: Thu Jan 1 01:00:00 1970
[1179983582.127474:032.0] Notification viability test passed.
[1179983582.127491:032.1] Current notification number: 2
[1179983582.127504:032.2] Creating list of contacts to be notified.
[1179983582.127514:032.1] Host notification will NOT be escalated.
[1179983582.127526:032.2] Adding contact 'nagiosadmin' to notification list.
[1179983582.128059:032.2] ** Attempting to notifying contact 'nagiosadmin'.=
=2E.
[1179983582.128075:032.2] ** Checking host notification vi
...[email truncated]...
