[Nagios-devel] Docs 3.0: clusters.html
Hi Ethan,
as with nagios-plugins-1.4.10, check_cluster uses the same command line
interface as check_cluster2 from ./contrib in earlier versions.
So, if check_cluster2 is renamed to check_cluster and will be regularly
installed, your documentation (cluster.html) did not match.
Ton, can you confirm this?
Wolfgang
* http://www.swobspace.de
Original poster: [email protected] (Wolfgang Barth
