Re: [Nagios-devel] -epn seems not work in 3.x
Hi Ethan, hi al,
I think there is a problem in base/utils.c, when comparing the string,
found in the perl script with
"+epn" or ".epn" .
There Ehtan has used strcmp
if(!strcmp(ptr,"+epn")){
use_epn=TRUE;
found_epn_directive=TRUE;
else if(!strcmp(ptr,"-epn")){
use_epn=FALSE;
I think (I'm not amn c expert) instead of strcmp, strstr would be better
due to leading/trailing whitespaces linefeeds in ptr. actually
actually with
# nagios: -epn"
ptr will be " +epn\n", the leading blank as well as the trailing
linefeed is part of ptr
regards,
peter
william(at)elan.net schrieb:
> On Wed, 11 Jul 2007, Hendrik Baecker wrote:
>> Hi Ingo,
>> Ingo Lantschner schrieb:
>>> But to my understanding of the tag "#nagios: -epn" it should disable
>>> epn for the particular plugin even if use_embedded_perl ist set to 1.
>>> But unfortunately the output still gets messed up.
>> yes - this should do the trick, but after regarding the docs it should be
>> "# nagios: -epn" instead of
>> "#nagios: -epn"
>> There is a blank between '#' and 'n'.
> While this is all fine, a simple way (that also works with any 2.x
> code) based on how nagios decides if it is or not a perl plugin is to
> just remove the first line "#!/usr/bin/perl" from pliugin and in
> commands.cfg instead of just specifying plugin name directly add
> explicit call to /usr/bin/perl, i.e.
> command_line /usr/bin/perl your_plugin.pl
