Hi there,
I juste upgraded nagios to 3.0.5 and discovered a little bug with the
command cgi.
If you want to submit a command (like Disable notifications for all
services on this host) and you check "Disable notification for host
too", the command is not correctly sent to Nagios.
Here's the logfile result (:
[1225963577] EXTERNAL COMMAND:
ENABLE_HOST_SVC_NOTIFICATIONS;hesidp[1225963577]
ENABLE_HOST_NOTIFICATIONS;hesidp
As you can see, there's a missing new line, thus making 2 commands on
one line, and unreadable for nagios.
I saw that the code of cgi/cmd.c has been changed, I tried to simply add
a \n in the cmd_submitf() function, but didn't work.
could you please look into this problem, and submit a patch ?
Thanking you,
Olivier B.
Olivier Beytrison
Network & Security Engineer, HES-SO Fribourg
Mobile: +41 (0)78 619 73 53
Mail: [email protected]
