[Nagios-devel] Re: [Nagios-users] more problems installing nagios 2.0b1
A patch to disable (un)setenv() calls will be in CVS shortly. Thanks
for reporting this.
On 15 Dec 2004 at 11:19, StinkyBob wrote:
> I commented out those two lines, and added a printf(""); in each one's
> place just in case it would screw up the if statement.
> next time I did a "make all", it worked!
> Thanks,
> -Stinky
> -----Original Message-----
> From: Andreas Ericsson [mailto:[email protected]]
> Sent: Wednesday, December 15, 2004 8:49 AM
> To: [email protected]
> Subject: Re: [Nagios-users] more problems installing nagios 2.0b1
> StinkyBob wrote:
> > Here are the errors I'm getting when compiling 2.0b1. Any ideas?
> > (SunFire V210, Solaris 8)
> setenv(3) and unsetenv(3) are BSD'isms. I don't think they're
> available on solaris 8. Comment them out and try again (they're not
> exactly crucial to operations anyway).
> You might want to send email like this to nagios-devel in the future.
> > -Stinky
> > ------ [machine@/usr/local/src/nagios-2.0b1]$ make all cd ./base &&
> > make [unnecessary compiling deleted here] gcc -g -O2 -DHAVE_CONFIG_H
> > -DNSCORE -o nagios nagios.c broker.o nebmods.o checks.o config.o
> > commands.o events.o flapping.o logging.o notifications.o
> > sehandlers.o utils.o retention-base.o xretention-base.o
> > comments-base.o xcomments-base.o objects-base.o xobjects-base.o
> > statusdata-base.o xstatusdata-base.o perfdata-base.o
> > xperfdata-base.o downtime-base.o xdowntime-base.o -lm -lnsl
> > -lsocket -lpthread -ldl -lrt Undefined first
> > referenced
> > symbol in file
> > unsetenv utils.o
> > setenv utils.o
> > ld: fatal: Symbol referencing errors. No output written to nagios
> > collect2: ld returned 1 exit status *** Error code 1 make: Fatal
> > error: Command failed for target `nagios' Current working directory
> > /usr/local/src/nagios-2.0b1/base *** Error code 1 make: Fatal error:
> > Command failed for target `all'
> > SF email is sponsored by - The IT Product Guide
> > Read honest & candid reviews on hundreds of IT Products from real
> > users. Discover which products truly live up to the hype. Start
> > reading now. http://productguide.itmanagersjournal.com/
> > _______________________________________________ Nagios-users mailing
> > list [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-users ::: Please
> > include Nagios version, plugin version (-v) and OS when reporting
> > any issue. ::: Messages without supporting info will risk being sent
> > to /dev/null
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Lead Developer
> include Nagios version, plugin version (-v) and OS when reporting any
> issue. ::: Messages without supporting info will risk being sent to
> /dev/null
...[email truncated]...
