I know this is more of a nagiosplug issue, but I know most people are
also on this list, so:
There is a bug in the CVS version of check_by_ssh. When you use "-t #"
to set a timeout, you get a segmentation fault and core dump. But when
you use "--timeout=#" it works fine. This was under Linux RedHat 7.2
(checked from the command line).
-Russell
Russell Scibetti
Quadrix Solutions, Inc.
http://www.quadrix.com
(732) 235-2335, ext. 7038
