Re: [Nagios-devel] Nagios 2.6 still not draining command pipe fast
In message ,
Ethan Galstad writes:
>John P. Rouillard wrote:
>> Hi all:
>> I am trying to get my external correlation engine working with nagios
>> 2.x , and I just can't get
>> nagios to drain the command pipe fast enough. I see approx. 5% failure
>> rate on writing to the command pipe with an EAGAIN error.
>> I have increased:
>> nagios.h:#define COMMAND_BUFFER_SLOTS 20480
>> nagios.h:#define SERVICE_BUFFER_SLOTS 20480
>> from the original 1024. In the increase of the settings from 10240 to
>> 20480, I may see a slight decrease (maybe .5%), but I think I just want to
>> see it. I don't think it's statistically viable.
>John - Does this problem still occur with Nagios 2.7 or the latest 2.x
>CVS code? A separate command file worker thread should be reading
>entries from the external command file as fast as it can read them (as
>long as their are free buffer slots).
I don't know. 2.6 was the latest when I started this. I will build it
later this week and report back.
>If there aren't any external commands, the thread waits 0.5 seconds
>before checking for new commands in the file. If you have occasional
>bursts of check results, this could be too long to wait. You could try
>experimenting with decreasing the 0.5 second delay. Around line 4948 of
>base/utils.c, you'll find...
>/* wait a bit */
>tv.tv_sec=0;
>tv.tv_usec=500000;
>select(0,NULL,NULL,NULL,&tv);
>You could try decreasing the value of tv.tv_usec to 100000 (0.1 seconds)
>and see if that helps at all.
Cool. Thanks. Maybe this is also a tuning parameter that could/should
be exposed in the configuation files?
If I get my external correlation patch working, would you consider
including the patch in the nagios core?
-- rouilj
John Rouillard
My employers don't acknowledge my existence much less my opinions.
------- End of Forwarded Message
