[Nagios-devel] patch: comments in configs
--=-F7J+X9mgd7uQ57MThdCp
Content-Type: text/plain
Tiny patch to keep a couple comment variations in main and object
configuration files from failing the pre-flight check.
Matthew Kent \ SA \ bravenet.com \ 1-250-954-3203 ext 108
Content-Disposition: attachment; filename=nagios-2.0a1-comments.patch
Content-Type: text/x-patch; name=nagios-2.0a1-comments.patch; charset=
diff -U 3 -r nagios-cvs_orig/base/config.c nagios-cvs/base/config.c
--- nagios-cvs_orig/base/config.c Thu Mar 25 22:04:04 2004
+++ nagios-cvs/base/config.c Fri Mar 26 21:15:03 2004
@@ -3,7 +3,7 @@
* CONFIG.C - Configuration input and verification routines for Nagios
* Copyright (c) 1999-2004 Ethan Galstad ([email protected])
- * Last Modified: 03-25-2004
+ * Last Modified: 03-26-2004
* License:
@@ -237,12 +237,16 @@
/* process all lines in the config file */
for(current_line=1,fgets(input,MAX_INPUT_BUFFER-1,fp);!feof(fp);current_line++,fgets(input,MAX_INPUT_BUFFER-1,fp)){
- /* skip blank lines and comments */
- if(input[0]=='#' || input[0]=='\x0' || input[0]=='\n' || input[0]=='\r')
+ /* skip blank lines */
+ if(input[0]=='\x0' || input[0]=='\n' || input[0]=='\r')
continue;
strip(input);
+ /* skip comments */
+ if(input[0]=='#' || input[0]==';')
+ continue;
/* skip external data directives */
if(strstr(input,"x")==input)
continue;
diff -U 3 -r nagios-cvs_orig/xdata/xodtemplate.c nagios-cvs/xdata/xodtemplate.c
--- nagios-cvs_orig/xdata/xodtemplate.c Wed Mar 24 17:03:56 2004
+++ nagios-cvs/xdata/xodtemplate.c Fri Mar 26 21:17:07 2004
@@ -3,7 +3,7 @@
* XODTEMPLATE.C - Template-based object configuration data input routines
* Copyright (c) 2001-2004 Ethan Galstad ([email protected])
- * Last Modified: 03-24-2004
* Description:
@@ -463,7 +463,7 @@
/* grab data before comment delimiter - faster than a strtok() and strncpy()... */
for(x=0;input[x]!='\x0';x++)
- if(input[x]==';')
+ if(input[x]==';' || input[x]=='#')
break;
input[x]='\x0';
--=-F7J+X9mgd7uQ57MThdCp--
