Re: [Nagios-devel] Minor problem in
Done. Thanks!
On 18 Sep 2002 at 13:49, Philip Warner wrote:
> The command 'check_local_procs' actually requires 3 args, not 2, so the
> code in services.cfg-sample is wrong:
> check_command check_local_procs!150!200
> it should read something like:
> check_command check_local_procs!150!200!R,Z,S,RS,RSZDT
> although I am not sure about the appropriate values in the last arg.
> Philip Warner | __---_____
> Albatross Consulting Pty. Ltd. |----/ - \
> (A.B.N. 75 008 659 498) | /(@) ______---_
> Tel: (+61) 0500 83 82 81 | _________ \
> Fax: (+61) 0500 83 82 82 | ___________ |
> Http://www.rhyme.com.au | / \|
> | --________--
> PGP key available upon request, | /
> and from pgp5.ai.mit.edu:11371 |/
> This SF.NET email is sponsored by: AMD - Your access to the experts
> on Hammer Technology! Open Source & Linux Developers, register now
> for the AMD Developer Symposium. Code: EX8664
> http://www.developwithamd.com/developerlab
> Nagios-devel mailing list
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
