Re: [Nagios-devel] Nagios stop hangs in FUTEX_WAIT
Herbert Straub wrote:
> If i try to stop nagios with /etc/init.d/nagios stop on Fedora Core 4/6
> with Nagios 2.4 and 2.7 the message:|
> Warning - running nagios did not exit in time|
> |The nagios process hangs in futex wait - example:|
> root@xen1 ~]# strace -p 11620
> Process 11620 attached - interrupt to quit
> futex(0x2aaaabf15980, FUTEX_WAIT, 2, NULL
> This happens not every stop, but 60% of the stop tries. I build nagios
> with debugging info and attach to the hanging process with gdb and see
> three threads with the following stack trace:
> thread 1:
> #0 0x0000003663ad9298 in __lll_mutex_lock_wait () from /lib64/libc.so.6
> #1 0x0000003663a730e8 in _L_lock_14830 () from /lib64/libc.so.6
> #2 0x0000003663a723ab in realloc () from /lib64/libc.so.6
> #3 0x0000003663a66224 in _IO_mem_finish () from /lib64/libc.so.6
> #4 0x0000003663a5e2ef in fclose@@GLIBC_2.2.5 () from /lib64/libc.so.6
> #5 0x0000003663ac9bf1 in __vsyslog_chk () from /lib64/libc.so.6
> #6 0x0000003663aca120 in syslog () from /lib64/libc.so.6
> #7 0x0000000000424227 in write_to_syslog (buffer=0x7fffa9aaaeb0 "Caught SIGTERM, shutting down...\n", data_type=64) at logging.c:229
> #8 0x00000000004248c9 in write_to_all_logs (buffer=0x7fffa9aaaeb0 "Caught SIGTERM, shutting down...\n", data_type=64) at logging.c:123
> #9 0x000000000042b09e in sighandler (sig=) at utils.c:3410
> #10
> #11 0x0000003663a94809 in fork () from /lib64/libc.so.6
> #12 0x000000000042f8b2 in my_system (cmd=0x7fffa9aac6b0 "/usr/local/share/nagios2/eventhandlers/process_perfdata.pl", timeout=5, early_timeout=0x7fffa9aacebc, exectime=0x7fffa9aaceb0, output=0x0, output_length=0) at utils.c:2699
> #13 0x00000000004536a3 in xpddefault_run_service_performance_data_command (svc=0x14672c0) at ../xdata/xpddefault.c:469
> #14 0x0000000000453729 in xpddefault_update_service_performance_data (svc=0x1200011) at ../xdata/xpddefault.c:400
> #15 0x0000000000453305 in update_service_performance_data (svc=0x1200011) at perfdata.c:91
> #16 0x0000000000413855 in reap_service_checks () at checks.c:1396
> #17 0x0000000000421ad2 in handle_timed_event (event=0x778c30) at events.c:1254
> #18 0x0000000000421e73 in event_execution_loop () at events.c:965
> #19 0x000000000040efa7 in main (argc=, argv=, env=0x7fffa9aae280) at nagios.c:710
> |thread 2:
> #0 0x0000003663ac4a36 in poll () from /lib64/libc.so.6
> #1 0x0000000000429ace in service_result_worker_thread (arg=) at utils.c:4775
> #2 0x0000003664606305 in start_thread () from /lib64/libpthread.so.0
> #3 0x0000003663acd50d in clone () from /lib64/libc.so.6
> thread 3:
> #0 0x0000003663ac6ac2 in select () from /lib64/libc.so.6
> #1 0x000000000042996e in command_file_worker_thread (arg=) at utils.c:4943
> Source part of thread 1:
> else if(sig
> sigshutdown=TRUE;
> sprintf(temp_buffer,"Caught SIG%s, shutting down...\n",sigs[sig]);
> ---> write_to_all_logs(temp_buffer,NSLOG_PROCESS_INFO);
> Source part of thread 2:
> while(1){
> /* should we shutdown? */
> pthread_testcancel();
> /* wait for data to arrive */
> /* select seems to not work, so we have to use poll instead */
> pfd.fd=ipc_pipe[0];
> pfd.events=POLLIN;
> ---> pollval=poll(&pfd,1,500);
> Source part of thread 3:
> while(1){
> /**** POLL() AND SELECT() DON'T SEEM TO WORK ****/
> /* wait a bit */
> tv.tv_sec=0;
> tv.tv_usec=500000;
...[email truncated]...
