the .in file for @localstatedir@ that's missing the last @ sign so it does=
n't replace it during the 'make'
Dan
On Oct 3, 2012, at 2:49 PM, Mike Guthrie wrote:
> Greetings,
>=20
> Working on testing an upgrade from Core 3.4.1 to 4.x for those who may=20
> want to migrate to 4. After some doing some house cleaning and removing=20
> deprecated config directives, the following issue still presented itself=
=20
> in the logs:
>=20
> [1349292382] Nagios 3.99.95 starting... (PID=3D28837)
>=20
> [1349292382] Local time is Wed Oct 03 14:26:22 CDT 2012
>=20
> [1349292382] LOG VERSION: 2.0
>=20
> [1349292382] Init of query socket '@localstatedir/rw/nagios.qh' failed. b=
ind() failed: No such file or directory
>=20
> [1349292382] Error: Failed to insert query handler 'nerd' (0x19d0a70) int=
o hash table (nil) (-22): No such file or directory
>=20
> [1349292382] Error: Failed to register 'nerd' with query handler
>=20
> [1349292382] Finished daemonizing... (New PID=3D28838)
>=20
> [1349292384] Successfully launched command file worker with pid 28841
>=20
> [1349292384] Workers spawned: 6
>=20
> [1349292384] Error: Failed to insert query handler 'register_worker' (0x1=
9d3770) into hash table (nil) (-22): Operation now in progress
>=20
>=20
> From looking through the code, the issue was resolved by specifying the=20
> following in the main nagios.cfg.
>=20
> query_socket=3D/usr/local/nagios/var/rw/query.sh
>=20
>=20
> It looks like there's supposed to be an error message that tells a user=20
> to add this, but for some reason it skipped past this and failed at the=20
> next conditional. Line 220 base/query-handler.c
>=20
> if(!path) {
>=20
> /* not configured, so do nothing */
>=20
> logit(NSLOG_INFO_MESSAGE, TRUE, "Query socket not enabled=
. Set 'query_socket=3D' in config (and stop whining,=
Robin).\n");
>=20
> return 0;
>=20
>=20
>=20
>=20
> --=20
>=20
>=20
> Mike Guthrie
> Technical Team
> ___
> Nagios Enterprises, LLC
> Email: [email protected]
> Web: www.nagios.com
>=20
>=20
> Don't let slow site performance ruin your business. Deploy New Relic APM
> Deploy New Relic app performance management and know exactly
> what is happening inside your Ruby, Python, PHP, Java, and .NET app
> Try New Relic at no cost today and get our sweet Data Nerd shirt too!
> http://p.sf.net/sfu/newrelic-dev2dev
> Nagios-devel mailing list
> [email protected]
